Marian78
Vand diverse
17 postări în acest subiect de discuţie despre Vand diverse
Vand diverse
Marian78
1. Panou solar semi flexibil 100w /18v Nou 900 ron
2. Regulator solar 20 A cu afisaj si iesiri 12 si 5 V Nou 250 ron
3. Bazin boiler Handiwash SH 600 ron
4. Set Mufe Y ( pt doua panouri) Noi 40 ron
5. Termometru electronic cu cablu pt frigider 30 ron
6. Voltmetru \ Ampermetru Nou 50 ron
7. Alarma cu cifru si buton de panica Noua 80 ron
8. Termostat cu afisaj 12v Nou 50 ron ( Pt adaugare ventilator in spatele frigiderului - se regleaza temp la care se sa plece vent.)
Marian 0766510399
Modificat de marian78
Salut @marian78
Oare o poza cu voltmetrul se poate?
Salutare @marian78 te rog dacă se poate ceva poze cu panoul , regulatorul , poate si celelalte că suntem interesați dar ...poza e poză ! Mulțumim !
Marian78
Incercam sa vedem daca reusim :)
Ok, merci
Marian78
Voltmetru 10A se monteaza pe circuit pt a afla consumul real al consumatorilor.
Marian78
Gata si regulatorul
LCD Screen 20A Solar Charge Controller Panel Battery Regulator Auto Switch Overload Protection Temperature Compensation 12V/24V
https://ae01.alicdn.com/kf/HTB1nuqyLVXXXXbgXFXXq6xXFXXX3/227752205/HTB1nuqyLVXXXXbgXFXXq6xXFXXX3.jpg
This solar charge controller adopts the advanced digital techniques and operates fully automatically. The PWM battery charging mode can greatly increase the lifetime of your battery and has various unique functions and quite easy to use features.
Features:
LCD screen display all parameters.
With output switch, intelligent control, easy to operate.
Fully automatic operation.
Microcontroller digital accuracy.
A key to open and close the load.
PWM charging mode(SOC).
With separated temperature detected circuit, high precision temperature compensation function.
DC 12V and USB 5V charging for DC lamp and phone.
Protection:
Overload protection;
Short-circuit protection;
Lighting protection;
Under-voltage protection;
Over-charging protection;
Reverse polarity protection.
Specifications:
Color: Black
Material: Plastic
Voltage of Battery: 12V / 24V Automatic
Rated Charge/Discharge Current: 20A
USB Output Voltage: 5V
Total USB Output Current: 3A
DC Output Voltage: 12V
Total DC Output Current: 2A
Overload/Short Circuit Protection: 1.5 Times by Rated Current
Short Circuit Recovery Time: 10s
Open Circuit Voltage of Solar Panel: 40V
No Load Loss: 0.05W
Over Voltage Protection: 15V; x2/24V
Float Charge Voltage: 14V; x2/24V
Discharge Recovery Voltage: 12V; x2/24V
Over Discharge Voltage: 10.5V; x2/24V
Control Mode: Software Intelligent Control
Working Temperature: -35~55°C
Item Size: 135 * 100 * 25mm / 5.31 * 3.94 * 0.98in (L * W * H)
Item Weight: 222g / 7.83oz
Package Size: 14.5 * 12 * 3.8cm / 5.7 * 4.72 * 1.5in (L * W * H)
Package Weight: 270g / 9.54oz
Package List:
1 * Solar Charge Controller
2 * DC Cable
1 * User Manual(English)
Marian78
Termostat Frigider
Pentru a racii mai bine frigiderul mai toata lumea a pus un ventilator sau doua in spate pe radiatorul frigiderului. Unii le-au pus simplu pe buton altii le-au pus pe un termostat mecanic luat de la masina de spalat, doar ca acesta citeste temperatura direct din spatele frigiderului(cine poate stie cat trebuie sa fie temperatura acolo?). Cu termostatul din imagine se introduce senzorul de temperatura in frigider(prin fanta de sus unde intra conducta subtire) si se setraza termostatul sa dea comanda la ventilator cand temp in frigider depaseste 7 grade C. Astfel nu mai avem grija ca se strica mancarea in frigider.
Marian78
Sau asa ceva  la 250 ron:
  • 1, wireless data transmission, eliminating the trouble of wiring, but also to avoid errors caused by line losses.
    2, bidirectional current detector for detecting the charging and discharging of the user can easily detect bidirectional current without changing the wiring.
    3, power and memory function, power failure after the settings can be saved before the power failure memory and when An, watts and time, to facilitate the observation and measurement.
    4, voltage, current, power, discharge capacity, and the time when the tile display simultaneously displays information fully clear.
    5, with overcurrent, overvoltage, undervoltage, limit protection (extended relay time) and other functions.
    6, when the number of security, and the time when the wattage clear function, does not affect the measurement.
    7, can be set up to address each individually, and with a view to display a plurality of measurement parameters measuring board.
    8, the use of multiple machines simultaneously, the machine can be set individually for each channel to avoid mutual interference.
    9, with a screen lock, time off, brightness adjustment and change the language display function.
    Specification:
    Self-powered measuring range 10V ~ 120V
    External power measurement range 0 ~ 120V
    Current measurement range of 0 ~ 50A
    Power measurement range 0 ~ 12KW
    Ah Measuring range 0 ~ 2000KAH
    Watt measurement range 0 ~ 4000KWH
    Time measurement range from 0 to 999 days
    Addressing range A01 ~ A99
    Wireless channel setting range 0 to 29
    Voltage 0.01V
    Current 0.01A
    Power 0.001W
    Capacity 0.001AH
    Wh 0.001WH
    Time 0.01H
    Voltage ± 1% + 2 words
    Current ± 2% + 5 words
    Sampling rate of 5 times / sec
    10 meters from the open communication to a single set of
    0.4W power consumption measurement plate
    Display panel power 0.5W
    NCP (negative overcurrent protection) 0 ~ -50A
    OCP (overcurrent protection Forward) 0 ~ 50A
    OVP (overvoltage protection) 0 ~ 120V
    LVP (undervoltage protection) 0 ~ 120V
    Delay protection time 0 ~ 10S
    Display board size (mm) 79 × 43 × 52 (mm)
    Measurement plate size (mm) 81 × 50 × 59 (mm)
  • Package Contents
    1xDC 120V 50A Wireless DC Voltmeter Ammeter Power Meter Capacity Coulomb Counter
în urmă cu 12 ore, marian78 a scris:
Se poate un pic mai explicit?
Marian78
în urmă cu 2 ore, George B a scris:
Marius Negru
Adica daca nu e armata si esti atacat poti apasa butonul de panica si face zgomot.
Marian78
Da. Daca vezi ca fortata usa sau intra ursul peste tine apesi si se actioneaza imediat.
Marian78
Up.
Panou, alarma si termostatul vandute. Restul valabil
